Turn Signal Problems
Old Jan 7, 2023 | 03:03 PM
JohnCG2002's Avatar
JohnCG2002 is on a distinguished road
Default Turn Signal Problems
I have a 2002 Blazer. Left turn signal only works with the headlights off. Any help would be appreciated. Thanks!
Old Jan 7, 2023 | 06:23 PM
First thing I would do is remove the headlight ground on the radiator support, clean it up, and make sure it's making good contact.
Old Jan 20, 2023 | 08:15 PM
JohnCG2002's Avatar
Tom A
I located 4 grounding wires from the light harness that attached to the core support. One wire came from the negative terminal of the battery. After cleaning all four connections, I checked the connections for ground. All have good ground, but I still have the same problem. I checked the left parking light socket for proper ground connection and compared it to the right light socket. Both have the same grounding. I'm ruling out a harness issue since the turn signal works fine with headlights off. Any chance it's the headlight switch?
Old Jan 21, 2023 | 10:12 AM
Knuckle Dragger's Avatar
Knuckle Dragger is on a distinguished road
Sounds like one of the filaments on the bulb shorted to the other. I would try a new bulb or swap them left to right to see if the problem follows.
Old Jan 22, 2023 | 07:47 AM
JohnCG2002's Avatar
The problem stays with the driver's side after switching bulbs.
9blazer5
Jan 13, 2017 10:54 PM
BLAZE1999
Aug 14, 2015 06:59 PM
OH_VDUB
Oct 12, 2011 04:17 PM
bubba8cake
Apr 14, 2011 03:18 PM
blazin97
Jun 15, 2005 05:51 PM
