Well that was an expensive touch, almost made it.
Old 05-07-2011 | 10:59 PM
streblo's Avatar
Default Well that was an expensive touch, almost made it.
So on the trip from winnipeg to whistler we almost made it with no problems. 2500km ish trip and about 200km out...coming up one of the last climbs blew the transmission cooler....and even awsome yet it blew inside the radiator...so now i have atf in the coolant and coolant in the transmission.......lost all the atf and the transmission started slipping......luckily was at the top of the climb so was able to nearly coast down until could find a shop to get it into to check the codes that were thrown when the engine light came one...basically engine ran fine, just the transmission overheated towing a trailer over the mountains........so basically torque converter stopped locking, then coming down the climb I dumped coolant through the over flow, stopped to let it cool and of course lost coolant and was empty...so........well we just happened to be stopped by a farmers field.that had sprinklers on..so it was a run out with water bottles dodging soggy cow pies to fill up water bottles to fill it back up and limp back down the pass into town, trying to keep it slow, torque converter wouldnt lock and eventually wouldnt shift into 4th gear....stop every once in a while to let it cool and keep going...made it to a shop and the codes were an over heated transmission and transmission slipping......luckily the shop i took it to they are really good, the owner phoned around to find us a hotel and paid for a cab to get us to the hotel to.......but its going to be an expensive fix, around the order of 1600 bucks..if only the cooler didnt have to blow inside the radiator..BAH.....have to get new radiator and getting a transmission cooler thrown in in line...so cooler will pass through the transmission first with their sad attemped at a transmission cooler, and then pass through the transmission cooler before going back to the transmission........so new radiator, new temp sensor..tranny cooler, thermostat, gasket..etc...and transmission service flush and new fluid..and then flush the coolant system twice with water and then again with coolant.....bah..all that adds up to a nice 1600 touch..OUCH.....but, was a nice trip..pics to come.........hopefully transmission wasnt damaged.
Old 05-07-2011 | 11:26 PM
DKSDAD's Avatar
That blows, I hope it all works out.
Old 05-07-2011 | 11:27 PM
Logan's Avatar
Logan is on a distinguished road
Good luck!
Old 05-08-2011 | 06:53 AM
wheelhead4x4's Avatar
wheelhead4x4 is on a distinguished road
Wow that sucks about the tranny. Good luck with it.
Old 05-08-2011 | 01:36 PM
streblo's Avatar
Thanks guys, hopefully everything works out fine and no other major issues and the transmission is fine. At leats getting a transmission cooler put in............Anyone know if theres an easy spot to put a temp gauge into the transmission?
Heres some pics from the trip. More to come when we make it the rest of the way
flooding
mfd70
07-19-2010 11:11 AM
mikejoann
01-04-2010 11:23 AM
supermancs
10-10-2007 05:03 AM
S10Blazer
Engine & Internal
10-08-2006 03:02 PM
