what to do
Old Jul 8, 2008 | 12:50 PM
kidd's Avatar
kidd is an unknown quantity at this point
Default what to do
I just got a 01 blazer. 2w I want to put a 2' body lift and a 4' suspesion lift on it. Can i do it, and will it be safe? Ialso wantto run 33 on it. What do i need to do for it to work? thanks
Old Jul 8, 2008 | 12:55 PM
WolfPack's Avatar
Default RE: what to do
Welcome to the site!
Spend some time browsing around the forums, this has all been covered before. Read this page first: Lift Kit List
I'm guessing you left off the d in your vehicle info, and you meant to type 01 blazer 2wd...and if that's the case, you might be able to go up 4' with the suspension. The 4x4 trucks max at 2' unless you spring for the VERY expensive 5' kits..but I think on a 2wd you can go higher since you dont have the whole front differential thing.
You'd probably have to flip the rear springs, then get lift spindles and lift springs up front for the full 4'. Although I would question why you want to run 33s on a 2wd truck
Old Jul 8, 2008 | 05:21 PM
djdrew010's Avatar
djdrew010 is an unknown quantity at this point
I would question lifting a 2wd truck. My motto is 2wd lower 4wd lift.
Old Jul 8, 2008 | 08:02 PM
WolfPack's Avatar
The problem with lifting a 2wd truck and putting the big A/T tires on is that after a while, you start to think that your truck really is offroad capable...then...you get stuck [&o]
Old Jul 8, 2008 | 11:36 PM
Idriveachevy's Avatar
Idriveachevy is an unknown quantity at this point
If i were doing it for a show truck i'd do a 2wd..
Old Jul 9, 2008 | 08:01 AM
kidd's Avatar
They make a 3.5 suspension kit for it. Or how can i make it a 4x4? I already put a supercharger on it i pull 8 psi on it. I want to go offroad a little bit. I real don't want to lower it. so what do yall recommended?
Old Jul 9, 2008 | 10:13 AM
djdrew010's Avatar
pics.....
Old Jul 9, 2008 | 04:46 PM
blazin97's Avatar
blazin97 is on a distinguished road
pics of this supercharged blazer??
why do you want to lift a 2wd??
The easiest way to make it 4wd is to get a frame from a 4wd and put your body on it.
Old Jul 9, 2008 | 08:35 PM
WolfPack's Avatar
But with the prices of SUVs in our gas-oriented days....just buy a 4wd.
Unless of course you really are supercharged..then you would want to drop body. And I'm no supercharger expert...but why spend the $4000 on a blower when you could have run 8lbs boost from a turbo for 1/4 of the cost if not less?
Old Jul 9, 2008 | 10:00 PM
djdrew010's Avatar
with that 4 grand i would of put it towards a sb
