whats the average life of a 4.3
i was just curious what the average life is on the 4.3, i have a 94 that just hit 230,000 miles still all original except for exhaust and air filter. I can still take off from a stop sign and burn the tires off the rim if i wanted to. Haven't decided if i want to rebuild the motor when it goes or do a v-8 swap. I also heard once the 4.3's hit 200,000 miles its hard to keep them running.
Ive had 2 s10 blazers,a 91 2wd,a 91 4wd(still have it). 1st one had 362,000 miles on it. I used 3 quarts of oil a WEEK. but still ran great. Me and a few guys at the shop tried blowing it by beating the sh out of it on the road and it still never blew.ended up wrecking it. The one i have now has 210k miles and its doing ok. burning some oil,but runs great. 4.3 tbi for the win!
Mine is also a '94 currently at 274,000 miles doesn't use a drop of oil and runs as strong as ever, it's all about maintenance and not beating it to death. This lil 4.3 CPI has been very good to me although it soon will come out in favor of a v8 when I do the SFA just because I want to.
I have 147,000 miles on my jimmy, and no issues to speak of.
nearing 184k time for an oil change but no probs with the engine, just the fuel pump but thats all done and over with, the tires and alignment are the only thing really wrong with it
I replaced my engine at around 360K. It was still running but not as strong. I installed a GM Remanufactored 4.3 Long Block.
My 4.3 has 120k on it and my motor is pretty much blown up. Iv put over 700 miles on it with the piston hitting the cylinder head. I knew the motor was gonna blow up so I beat on it and after 700 miles of me trying to blow it up it finally happened the other night. I mean it runs right now but it runs like crap. Its running on 0 oil pressure and when I step on the gas the oil pres goes up a tiny bit. They are real good motors if you take care of them (the previous owner of my blazer didn't). The 4.3 is pretty much a small block chevy, minus the back 2 pistons.
Too many variables to say how long a 4.3 will last.
Bottom line, you take care of your engine and it will take care of you. Same goes with everything else on the vehicle. |
165 000 KM on the body but 85 000 KM on the Engine ... Still going strong!
In miles is: 102 000 Miles on the body and 52 000 Miles on the Engine if i'm correct! |
mine has just turned over 180k miles. burns a little oil but runs just as strong as it did teh day i got it. but thinking about trading mine for a full size truck.
i got 130,000. a guy i work with has got over 200,000 with the stock tranny. they are a good "stock" motor. you start doing serious modifications. supercharger, radical cam. etc. they don't last long. they were based of the 350s and the 350s were a dam good motor.
GM 4.3L engine 280800 miles
I changed the tie rods, ball joints to make a good Chevy again, and was discouraged by a starting problem
on warm days. After changing the starter and ignition coil, I discovered it was the distributor rotor loosing sparks and a new distributor assembly was only $45.00. The whole distributor changed made a new Chevy again. The engine does not use any oil at high miles. I change it at 5000 miles, and have a new Chevy again after the mystery of hard starting during warm days was solved with the whole distributor changed out. Put the old one in TDC at the mark and then put the new one in as a easy swap out with only one bolt holding it in. Turn the engine with the generator hex bolt to TDC, marked by the old distributor or number one cylinder, (first one to the right from the front) to TDC by having the pressure exhausted and then the suction starts. |
Mine is at 135k miles. If there is a worry on my part it is that I might have an oil leak from either the front or rear crank seal. Since I got it at about 88k miles I've been religious with oil changes and keeping it from overheating. I recently switched to synthetic oil and will do my first oil change on it at only 2,000 to 3,000 miles as I expect the new oil to absorb lots of old gunk. I'm hoping to get at least another 50k to 70k miles out of it.
BTW, I'm encouraged with number of motors I hear of that have gone well over 200,000 miles. :-) |
I've a 94 4x4 at some 195k still running strong. Tune up three years ago, some vacuum lines. Oil consumption still normal and still going strong.
Building an engine for it but not that I would need one now. Just for the fun of it. |
'97 LT Blazer 4x4 here with original engine and trans (afaik) and I'm at 265k miles. I had to replace the lower intake gasket last summer at around the 260k mark, so I'm optimistic she'll make it to 300k for me. ::knock on wood:: The guys at the oil change shop always remark on how clean the fluid is. People can be religious about the type of fluid you use and for how many miles you stretch it...I use Max Life 5/30 Synthetic for High Mileage and change it every 3-4k miles. I change my trans fluid every couple of years. I thought I was doing pretty well 'til I met a home inspector who had 400k on his 1500, so these days I'm not nearly as proud of my greater-than 250k miles as I used to be. lol
I met a guy with an s10 who had 927xxx on all original. And I just sold a zr2 s10 about a year ago with 854xxx all original. Really I guess it's just based on maintenance and luck of the production line...
1st edit: Forgot to mention that's in KM 2nd edit: 875xxx not 854xxx |
I've got 332K miles on mine. Other than the usual problems, mainly fuel system, it's been good to me. Never been in it past the manifold. Original transmission. Was leaking some oil, but it was the oil cooler lines. Fixed those (for the second time) now it's all tight again.
Did a compression test on it about two years ago, can't remember the exact numbers, but they were all damn near the same, and fairly high, considering the age. They're good engines. Like everyone's said, it's a 350 small block, minus a cylinder on each side. Maybe not the most efficient, or powerful, but it'll run forever, as long as you do your part. |
I had a 1993 GMC Sonoma w/ a TBI 4.3. It had 240,000 miles on it when I sold it. The only problem I ever had out of it was that the freeze plugs started to leak antifreeze. The first time I had them replaced, they didn't leak for about one year. After the second time I had them replaced they only lasted a few months before leaking again. I sold the truck to a guy looking for the square body to make a V8 street rod.
The 4.3, in my opinion, is bulletproof when properly maintained. _____________________________ 1999 Blazer LT 4dr, Auto-4WD, AT Bilstein 4600 Series Shocks Axle: 3.42:1 w/ Eaton Detroit Truetrac Locker Tires: 235/75-15 Michelin LTX A/T2 Gibson cat-back exhaust K&N CAI Hypertech Power Programmer Tune |
