wich chevy,s come standard with dana60front an 14boltrear axles ?
Somebody know this ?
Sorry for the newby question but im planning to buy one but i want the one with the strongest axles to put big tires for offroading:icon_pirate: (11.00r16 mischelin military tires) Friendly regards ! |
nobody know this ?:icon_toast:
pre 91 chevy k30s im not quite sure how far back they go but anything from the early 80s to 91 will have them. they get kinda pricey i got lucky and found mine with the rotted out turd truck still attached for $800
not quite sure about the ford models also, but some of those come with a dana 60 front. |
Oke thanks and i red the k5 blazer has also d60front 14bolt rear right ?
Originally Posted by buschmaster
(Post 505025)
14BFF axles out from under a 1-ton truck will require movement of the spring perches due to the position of the leaf springs on those chassis. If you find a 14BFF out of a 3/4 ton pickup, it will bolt right in. 3/4 ton pickups of the era had HD 10-bolts or Dana 44's though so don't get fooled by the 8-lug outers. |
| All times are GMT -5. The time now is 01:27 AM. |
