wich chevy,s come standard with dana60front an 14boltrear axles ?
Old Mar 9, 2012 | 06:02 PM
buschmaster's Avatar
buschmaster is on a distinguished road
Default wich chevy,s come standard with dana60front an 14boltrear axles ?
Somebody know this ?
Sorry for the newby question but im planning to buy one but i want the one with the strongest axles to put big tires for offroading (11.00r16 mischelin military tires)
Friendly regards !
Old Mar 11, 2012 | 06:03 PM
Wink
nobody know this ?
Old Mar 12, 2012 | 07:18 PM
abig84's Avatar
pre 91 chevy k30s im not quite sure how far back they go but anything from the early 80s to 91 will have them. they get kinda pricey i got lucky and found mine with the rotted out turd truck still attached for $800
not quite sure about the ford models also, but some of those come with a dana 60 front.
Old Mar 13, 2012 | 09:03 AM
Oke thanks and i red the k5 blazer has also d60front 14bolt rear right ?
Old Mar 13, 2012 | 09:10 AM
The only K5's that came with this combo were the military versions that did have the 1-ton running gear (Dana 60 front / 14-bolt FF rear). They are referred to as the M1009 CUCV.
14BFF axles out from under a 1-ton truck will require movement of the spring perches due to the position of the leaf springs on those chassis. If you find a 14BFF out of a 3/4 ton pickup, it will bolt right in. 3/4 ton pickups of the era had HD 10-bolts or Dana 44's though so don't get fooled by the 8-lug outers.
Diverknox
Dec 6, 2009 11:48 PM
Bad Ramer Jamer
Sep 12, 2008 08:10 PM
Bad Ramer Jamer
Sep 12, 2008 06:55 AM
hls811
Jan 17, 2008 10:40 PM
webbyj883
Suspension Tech
Sep 9, 2005 02:15 PM
