wont start now
Old Jan 3, 2021 | 06:40 AM
lcollims's Avatar
lcollims is on a distinguished road
Default wont start now
i lost my keys and tried to hot wire it and now i got new ignition but it dobt want to start all of the sudden
Old Jan 3, 2021 | 10:58 AM
Try this process to relearn the anti-theft system. Make sure your battery is fully charged before starting.
30 Minute Re-Learn Procedure
  1. Turn ON the ignition, with the engine OFF.
  2. Attempt to start the engine, then release the key to ON (vehicle will not start).
  3. Observe the SECURITY telltale,[this is the security light in the instrument panel] after approximately 10 minutes the telltale will turn OFF.
  4. Turn OFF the ignition, and wait 5 seconds .
  5. Repeat steps 1 through 4 two more times for a total of 3 cycles/30 minutes (the vehicle is now ready to relearn the Passlock(TM) Sensor Data Code and/or passwords on the next ignition switch transition from OFF to CRANK). IMPORTANT: The vehicle learns the Passlock(TM) Sensor Data Code and/or password XXXXX the next ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle.
  6. Start the engine (the vehicle has now learned the Passlock(TM) Sensor Data Code and/or password).
Old Jan 4, 2021 | 01:07 AM
Mods's Avatar
..does it crank at all? you didnt fry anything while hotwiring it right. What model year? if its a 2003-2005 it will have a Passlock Chip key and you need to make sure both the new lock cylinder and the new key have that system and that it is plugged in.
Kangblazer
Jun 15, 2017 03:40 PM
2000_blazer
Jul 28, 2013 09:16 PM
Rudescot65
Nov 19, 2008 12:49 PM
nelson 710
Oct 19, 2008 08:52 AM
