ZR2 axle swap
Old Mar 17, 2009 | 01:13 PM
W2JGA's Avatar
W2JGA is an unknown quantity at this point
Question ZR2 axle swap
I found an ad on Craigslist for a ZR2 partout. Will the rear axle swap out evenly?
Old Mar 17, 2009 | 01:21 PM
Should be no problem as far as bolting in.
Old Mar 17, 2009 | 11:04 PM
AJBert's Avatar
Evenly? As in width? No, it will be wider.
Shoudl be a pretty easy sway, though.
Old Mar 17, 2009 | 11:22 PM
NVANZEE's Avatar
you wanna make sure the gearing is the same as the front diff. If not you will have to change one or the other
Old Mar 18, 2009 | 12:24 AM
WolfPack's Avatar
If you have a 2-door non-z then yes it will. If you have a 4-door, you need to grab the rear brake lines, specifically, the T that comes down at the axle. I think theres something with the rear sway bar too...but I cant recall.
Gary, TripleBlackBlazer should be able to help you out.
x2 on the gearing...ZR2s have 3.73s, you probably have 3.42s...probably..
Old Mar 18, 2009 | 05:55 AM
W2JGA's Avatar
Thanks for the input guys!
AJBert, I knew the axle was wider than the stock one, thus the reason I want one. But, it's been brought to my attention that the front axle gear ratio must match the rear also. Well, I guess I will go back to getting spacers instead.
Would like to stick a G80 in the rear end though!
Old Mar 18, 2009 | 07:17 AM
z28jeff's Avatar
z28jeff is an unknown quantity at this point
[QUOTE=WolfPack;205909]If you have a 2-door non-z then yes it will. If you have a 4-door, you need to grab the rear brake lines, specifically, the T that comes down at the axle. I think theres something with the rear sway bar too...but I cant recall.
[QUOTE]
4 doors have the rear swaybar routed across the back of the rear end. 2 doors have it routed in the front, over the yoke.
W2JGA: I think all ZR2's have G80.
Old Mar 18, 2009 | 08:12 AM
W2JGA's Avatar
Ok, is it possible to pull the G80 out and put it in mine?
Old Mar 18, 2009 | 08:33 AM
z28jeff's Avatar
ZR2's have 30 spline 8.5 rear ends. NonZR2's have 28 spline 7.625 rears. Their differentials are not interchangable.
Old Mar 18, 2009 | 10:42 PM
AJBert's Avatar
If you can also get the front diff that would solve the gearing issue. I'm pretty sure the front diffs are the same between a Z and non-Z.
