-   General Chat (https://blazerforum.com/forum/general-chat-34/)
-   -   ZR2 axle swap (https://blazerforum.com/forum/general-chat-34/zr2-axle-swap-28792/)
W2JGA Mar 17, 2009 01:13 PM
ZR2 axle swap
I found an ad on Craigslist for a ZR2 partout. Will the rear axle swap out evenly?
swartlkk Mar 17, 2009 01:21 PM
Should be no problem as far as bolting in.
AJBert Mar 17, 2009 11:04 PM
Evenly? As in width? No, it will be wider.
Shoudl be a pretty easy sway, though.
NVANZEE Mar 17, 2009 11:22 PM
you wanna make sure the gearing is the same as the front diff. If not you will have to change one or the other
WolfPack Mar 18, 2009 12:24 AM
If you have a 2-door non-z then yes it will. If you have a 4-door, you need to grab the rear brake lines, specifically, the T that comes down at the axle. I think theres something with the rear sway bar too...but I cant recall.
Gary, TripleBlackBlazer should be able to help you out.
x2 on the gearing...ZR2s have 3.73s, you probably have 3.42s...probably..
W2JGA Mar 18, 2009 05:55 AM
Thanks for the input guys!
AJBert, I knew the axle was wider than the stock one, thus the reason I want one. But, it's been brought to my attention that the front axle gear ratio must match the rear also. Well, I guess I will go back to getting spacers instead.
Would like to stick a G80 in the rear end though!
z28jeff Mar 18, 2009 07:17 AM
[QUOTE=WolfPack;205909]If you have a 2-door non-z then yes it will. If you have a 4-door, you need to grab the rear brake lines, specifically, the T that comes down at the axle. I think theres something with the rear sway bar too...but I cant recall.
[QUOTE]
4 doors have the rear swaybar routed across the back of the rear end. 2 doors have it routed in the front, over the yoke.
W2JGA: I think all ZR2's have G80.
W2JGA Mar 18, 2009 08:12 AM
Ok, is it possible to pull the G80 out and put it in mine?
z28jeff Mar 18, 2009 08:33 AM
ZR2's have 30 spline 8.5 rear ends. NonZR2's have 28 spline 7.625 rears. Their differentials are not interchangable.
AJBert Mar 18, 2009 10:42 PM
If you can also get the front diff that would solve the gearing issue. I'm pretty sure the front diffs are the same between a Z and non-Z.
