General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
3rd brake light replacement
Old Sep 27, 2006 | 09:46 PM
magnum434's Avatar
magnum434 is an unknown quantity at this point
Default 3rd brake light replacement
So how do I get to the end of the cord connecting to the 3rd brake light...its buried in the headliner kinda...
Old Sep 28, 2006 | 01:26 AM
Chevy Lover's Avatar
Default RE: 3rd brake light replacement
If there is a rubber grommet that the wire goes into, remove the grommet to get to the connector.
Old Sep 28, 2006 | 10:27 AM
magnum434's Avatar
this may sound dumb but how do i get the gromment off...it goes into the headliner or someting.
Old Sep 28, 2006 | 06:40 PM
20Blazer00's Avatar
ORIGINAL: magnum434
You can either squeeze/pinch it with your fingers or use a pair of pliers, but be careful using pliers not to cut/tear the grommet when pulling it out of the hole it is in. There should be plenty of room for this, grommets are just there to keep the hole from chaffing the plastic sheathing of the wire, thus preventing a short circuit in the system...try not to pinch to hard or pull hard on the wires if the plug catches on the hole.
Old Sep 28, 2006 | 06:58 PM
magnum434's Avatar
Hey so i got the grommet off...but now the cord thing wont pull out to expose the little end on it...i dont wanna pull to hard because im afraid itll come disconnected and then i wont be able to get any lights back there...because there apparently is no other way to get up in there. Any advice?
Old Sep 30, 2006 | 04:28 AM
Can you get a little flashlight in there to see the connector? It might just need a little jiggling or some guiding with a long skinny screwdriver.
Old Sep 30, 2006 | 12:47 PM
magnum434's Avatar
ill look...but i really dont think so...i cold tell by sticking my finger in it that it was pretty close to being up against the back wall thing.
Old Sep 30, 2006 | 02:03 PM
Maybe long skinny needlenose pliers?
dano440
May 11, 2012 06:57 PM
NEW YORK BOY
May 23, 2011 01:18 PM
steveshane67
Jan 28, 2010 05:06 PM
drperry
Aug 16, 2009 05:24 PM
kiwiblazer
Sep 9, 2008 01:48 AM
