General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
4wheel drive
Old Nov 15, 2006 | 07:57 PM
chrissy's Avatar
chrissy is an unknown quantity at this point
Default 4wheel drive
what would cause front wheel s to not engage they lock up in rear end in 4 lo but not in the front had it scaned and came back encoder motor and changed that ans still nothing what was cause that for the front not to engage is there a shift motor under the battery cause i check all the fuses and relays and they r all good
what else can be the problem need help bad [:@]
Old Nov 15, 2006 | 09:18 PM
rooster's Avatar
rooster is an unknown quantity at this point
Default RE: 4wheel drive
depending of what ur pushin(repost with veh. info) there might be an actuator under the battery, but next time give us the info(4.3,2.8?; tbi,cpi?; year)
Old Nov 15, 2006 | 10:30 PM
chrissy's Avatar
SORRY ITS A 99 ZR2 WITH A 4 BUTTTON ON THE DASH IM NOT SURE WHAT IS GOING ON WITH IT AT ALL
THANKS FOR ALL THE HELP GUYS THIS THING IS A MONEY PIT AND ALL THE FREE ADVICE IS GOOD
Old Nov 15, 2006 | 10:54 PM
lastcoupe's Avatar
lastcoupe is an unknown quantity at this point
If your's has 4 buttons (1 says "auto") it has an electrically controlled solenoid mounted on the top center of the firewall above the distributor...that controls the front axle engaugement (routes engine vacuum to the front axle actuator under the battery tray). Does the 4Hi button continuously blink when you press it? If so then your front axle is not engauging....and your t-case is funtioning properly. First check the vacuum hoses to and from the solenoid....if o.k. check the cable from the actuator (again under the battery tray) to the front axle....I have seen MANY cases where the positive battery post leaks battery acid onto the cable and siezes it up....look straight down from the battery positive bolt if you recently changed a leaking battery.
diceman721
Oct 25, 2009 06:53 PM
missu
Feb 23, 2008 10:55 PM
kakn
Jul 22, 2007 09:14 AM
lowester
Apr 18, 2007 04:22 AM
lowester
Apr 6, 2007 09:30 AM
