General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
81 jimmy tailgate problem.
Old Mar 3, 2006 | 04:04 PM
Jimmiero's Avatar
Jimmiero is an unknown quantity at this point
Default 81 jimmy tailgate problem.
I just got it and after opening the tailgate twice it won't open anymore. It also doesn't roll down the window with the key anymore, i can only do it from the switch up from. Anybody have any ideas what it could be? Thanks
Old Mar 3, 2006 | 06:54 PM
20Blazer00's Avatar
Default RE: 81 jimmy tailgate problem.
Is the Key worn down a lot???? If it is then the tumblers in the lock may not be engaging correctly for the switch to turn on. And if that is not the case then you may have to open up the tailgate to check wiring from key switch to motor, wire severly corroded and needs replace or has broken inside sheathing and needs to be replaced....
RobRad
Mar 24, 2014 06:08 PM
Flapjack
Jan 16, 2007 10:35 AM
circletrack86
Jan 3, 2007 03:05 PM
90jimmy
Aug 4, 2006 02:16 AM
