General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
87 S10 body lift
Old Jun 2, 2006 | 04:48 PM
Jeremy_87_S10's Avatar
Jeremy_87_S10 is an unknown quantity at this point
Default 87 S10 body lift
I'd like to give it a 2" body lift. Do I need to account for anything or can I just jack it up and put spacers between the body and the frame? Will the steering column and wiring cause any problems?
Old Jun 3, 2006 | 08:02 PM
Default RE: 87 S10 body lift
anyone?
Old Jun 3, 2006 | 09:07 PM
cherryred4x4's Avatar
cherryred4x4 is an unknown quantity at this point
If you buy one of the kits, you should be alright. The only things to worry about are maybe the brake lines, steering column angle might change a little. Just be sure to check any linkages or wires that run from the frame to the body. Your fan shrouds wont line up once the body lift is on. If you get the performance accessories body lift kit, it should have all the instructions. Be sure to get the gap guards for at least the front wheel wells.
Old Jun 6, 2006 | 07:18 PM
Cool, Thanx
wlorton
Lifting Tech
16
Dec 26, 2009 05:05 PM
<3blazer
Suspension Tech
Jun 13, 2009 09:32 PM
Tippman7641
Apr 6, 2008 07:20 PM
blazerboy124
Suspension Tech
Aug 6, 2007 10:17 AM
third2121
Suspension Tech
Jul 25, 2005 02:23 PM
