General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
91 blazer starter problems
Old May 24, 2006 | 01:16 PM
keithscianna's Avatar
keithscianna is an unknown quantity at this point
Default 91 blazer starter problems
hey,
When i turn the key i just hear a clunking, the starter gets really hot if i hold the key in the start position,
thanks,
keith
Old May 24, 2006 | 02:18 PM
Mudvayne's Avatar
Mudvayne is an unknown quantity at this point
Default RE: 91 blazer starter problems
inspect your ground cables from the engine to chassis, and from the chassis to battery. If its getting hot the voltage is on the power side, but only letting a little through to ground, (trying to draw many more amps than is possible) Or you could have a locked up motor I suppose. try turning the engine over w/ key off in neutral with a wrench. Thier will be a giant bolt on the front of crankshaft pulley to do so.
Old May 24, 2006 | 06:32 PM
Ok i wil try the ground connections, i doubt the engine is sized up, It was running fine until one morning tried to start it., thanks
Old May 24, 2006 | 06:47 PM
I just checked and everything look tight, is there anywhere i should look at? also i just put a new battery in a couple months ago and there is a lot of corrosion on the positive side. thanks,
Old May 24, 2006 | 07:18 PM
Mudvayne's Avatar
To clean the battery cables, find sno-bol. Its toilet bowl cleaner, i believe cvs, walgreens etc will carry it, and a wire brush.
make sure you use some gloves also. scrub away, rinse with water, dry and re-connect. try starting. I would just clean both cables and posts while u are thier allready.
Old Jun 23, 2006 | 08:56 PM
oosickness's Avatar
oosickness is an unknown quantity at this point
my is doing somthing similar. it died at the bank this morning in like 100 degree weather. it just didnt do anything and it would not give me my key back. i jumped it and nothing happend and nothing had power lights locks radio ect.... payed to have it towed and it in the the home waiting for my to do somithng
jdmmario
Oct 25, 2014 06:25 PM
Leo1
Jul 17, 2011 02:14 AM
AtreyuManiac
May 26, 2009 07:43 AM
Tymaraux
Mar 18, 2008 02:49 PM
Joshua M. Smith
Sep 19, 2005 02:57 PM
