General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
94 Blazer S10 Tahoe
Old Nov 23, 2006 | 08:51 PM
evansblue24's Avatar
evansblue24 is an unknown quantity at this point
Default 94 Blazer S10 Tahoe
Ok I Have 94 blazer and it doesnt wanna turn over i can get it to run for a little bit then it shuts off then after a few turns of the key to get the pump to kick on it works then shuts right off or let it sit for a while then it starts runs for like 1 minutes then chokes it self out i replace the truck with a new fuel pump,fuel filter,MSD cap and rotor,MSD plug Wires,MSD coil, New Plugs autolite platnium,New Battery.. ran fine for a month or two with this stuff and now it wont run right and wnt run when the tank is at a little under the half mark can anyone help
Old Nov 23, 2006 | 11:25 PM
Mbastet99's Avatar
Mbastet99 is an unknown quantity at this point
Default RE: 94 Blazer S10 Tahoe
Maybe you got a bad (new) fuel pump? Have you checked the EGR to see if it's clogged? Not sure, just throwing out some ideas....
Old Nov 24, 2006 | 12:19 AM
Crashes's Avatar
Crashes is an unknown quantity at this point
Could be a MAP or MAF sensor cause if they dont see air coming in, they dont tell the fuel pump to send fuel. disconnect one or the other, and if it keeps an idle that could be your problem... That or your intake pipe is very loose.
Old Nov 24, 2006 | 06:24 PM
yeah the fuel pump i had in it still did it i was thinking what about the fuel pump regulator
teckmanAB
Jul 26, 2008 12:56 PM
jdoerrer
Oct 15, 2007 01:11 AM
Lockback
Aug 22, 2007 12:24 PM
cooter
Tires and Wheels
Oct 7, 2006 03:46 AM
Mariongo
Aug 31, 2006 12:52 PM
