General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
95 s10 blazer 4wd problem (tcem or tccm?)
Old Nov 10, 2006 | 07:22 PM
thaasjr's Avatar
thaasjr is an unknown quantity at this point
Default 95 s10 blazer 4wd problem (tcem or tccm?)
I was wondering if anyone could tell me what my 4wd problem is. It won't engage into 4 hi but will 4 low. I did the grounding test and the light blinks 4 times. I initially thought this meant its the transfer case encoder motor but after searching this sight see it may be the tccm. Which is it most likely to be and where is the tccm located on a 95?
Thanks
Old Nov 10, 2006 | 10:15 PM
lastcoupe's Avatar
lastcoupe is an unknown quantity at this point
Default RE: 95 s10 blazer 4wd problem (tcem or tccm?)
A code number 4 (lights blink 4 times) indicates a tccm (transfer case control module)RAM failure. On a 1995 it's in the center bottom of the dash...right behind the cig lighter outlets..it's a silver box about 3x5 inches..held in with 2-7mm screws.
Old Nov 13, 2006 | 02:03 PM
thaasjr's Avatar
will a tccm off of a 97 blazer interchange with my 95. If so are they in the same location?
Thanks
Tinted
Nov 29, 2011 02:06 PM
William Kimmel
Jan 6, 2011 06:18 PM
rastoma
Feb 10, 2010 02:43 PM
88s10Blazer
Jan 31, 2010 04:28 PM
