General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
97 Blazer Head Light issue
Old Jul 10, 2006 | 05:15 AM
mrspeedy69's Avatar
mrspeedy69 is an unknown quantity at this point
Default 97 Blazer Head Light issue
I have a 97 Blazer LS 4dr 4wd and my head lights do not work. I have checked all fuses and everything is ok. When i turned the switch for the lights on nothing happens, i can switch between bright and dim and nothing works. However when i release the parking break my day time running lights come on and thats all that will work even if i have the head light switch turned on. Does anyone know what might be causing this?
Old Jul 10, 2006 | 08:15 AM
lunatic_magnet's Avatar
lunatic_magnet is an unknown quantity at this point
Default RE: 97 Blazer Head Light issue
sounds like a bad on/off switch in the dash.
Old Jul 10, 2006 | 07:00 PM
mrspeedy69's Avatar
Ok thanks, do you know if they're expensive or hard to put in?
Old Jul 13, 2006 | 06:54 PM
magtec's Avatar
magtec is an unknown quantity at this point
the switch on the dash is a module that is very easy to replace, just grab one from the junkyard. all you need to do is pop off the dash bezel, the switch will come off with it. then just disconnect the wiring harness and replace the switch.
Old Jul 26, 2006 | 03:42 PM
mrspeedy69's Avatar
I just wanted to say thanks for the help with this, it was a bad on/off switch. I replaced it and it works perfect now. Thank you to all you guys.
Old Jul 26, 2006 | 04:32 PM
Dory's Avatar
Retired Super Moderator
Dory is a jewel in the roughDory is a jewel in the roughDory is a jewel in the rough
Feel free to recommend us, and keep posting!!
Old Jul 26, 2006 | 10:00 PM
Glad you got it fixed! Now don't be a stranger!
99bblazer99
Jun 15, 2013 08:38 PM
Rumblur
May 22, 2013 03:23 PM
echo1
15
Aug 28, 2012 07:56 PM
blazer78
Feb 13, 2012 07:18 PM
J.R. Clay
Mar 17, 2011 08:22 PM
