General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
99 chevy blazer fan clutch
Old Jul 3, 2006 | 10:00 PM
jerry300zx's Avatar
jerry300zx is an unknown quantity at this point
Default 99 chevy blazer fan clutch
my girlfriends 99 chevy blazer just had a new fan belt put on and now the fan is real loud and constantlty spinning, i try to spin it with my hand when the engine is off and it is reall hard to turn.
could they have over torqued the fan clutch bolts or is the fan clutch just bad?
jerry
Old Jul 3, 2006 | 10:08 PM
Chevy Lover's Avatar
Default RE: 99 chevy blazer fan clutch
ORIGINAL: jerry300zx
jerry
If you try to spin it when the engine is hot, it will be hard to turn. It should spin more easily when it's cold. The idea is that when the engine is hot, it's drawing more air through the radiator to cool and drawing less cooling air during engine warm-up.
[IMG]local://upfiles/2910/1D40D61A365F412D85375209CF9676BF.jpg[/IMG]
Old Jul 4, 2006 | 05:46 AM
20Blazer00's Avatar
jerry
Since the Blazer is a 1999 it uses a serpentine belt system, they would not have touched the clutch fan unless there were some obviously loose bolts. There is a spring loaded tensioner that keeps the belt tight and is loosened when the belt needs replacing. If the clutch fan is hard to turn when cold then consider replacing it if not then the noise is normal. And the only way to get rid of it is to convert to electric fan(s).
gitch93
Jul 23, 2013 08:06 AM
cheesequaker
Apr 25, 2012 01:44 PM
85kulan
Oct 4, 2011 09:51 AM
MintyMadness
Jul 13, 2011 12:37 AM
Red03
Sep 25, 2008 08:37 PM
