ABS Light?
I have a 97 Chevy Blazer LS. I just had new brakes put on but my ABS light in the dash won't turn off? Is this something I have to go to the dealer and have reset? Or does the sensor just need to be cleaned?
RE: ABS Light?
There is a current thread about this same problem. Check the forums for some good advice.
RE: ABS Light?
It could be a bad wheel bearing.
RE: ABS Light?
Check with the shop/people that did your brake work and see if they know what the problem might be. There may be something that happened during there work that may have caused this problem or they forgot to reinstall something causing the ABS light to go off ie: removed a sensor connection or accidentally knocked it off while bleeding the brake system and they just have to put the connector back on...
Could be a simple fix. |
RE: ABS Light?
Turns out the shop found the right front abs unplug or something like that after they fixed it the light turned off. Thanks for you're help!
RE: ABS Light?
Glad to hear it was something simple.
