General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
ABS Light?
Old May 14, 2006 | 11:09 PM
supermancs's Avatar
supermancs is an unknown quantity at this point
Default ABS Light?
I have a 97 Chevy Blazer LS. I just had new brakes put on but my ABS light in the dash won't turn off? Is this something I have to go to the dealer and have reset? Or does the sensor just need to be cleaned?
Old May 15, 2006 | 12:11 AM
hdlogistics's Avatar
hdlogistics is an unknown quantity at this point
Default RE: ABS Light?
There is a current thread about this same problem. Check the forums for some good advice.
Old May 15, 2006 | 01:08 AM
4lowlife's Avatar
It could be a bad wheel bearing.
Old May 15, 2006 | 04:32 AM
20Blazer00's Avatar
Check with the shop/people that did your brake work and see if they know what the problem might be. There may be something that happened during there work that may have caused this problem or they forgot to reinstall something causing the ABS light to go off ie: removed a sensor connection or accidentally knocked it off while bleeding the brake system and they just have to put the connector back on...
Could be a simple fix.
Old May 19, 2006 | 07:30 PM
supermancs's Avatar
Turns out the shop found the right front abs unplug or something like that after they fixed it the light turned off. Thanks for you're help!
Old May 20, 2006 | 12:25 AM
4lowlife's Avatar
Glad to hear it was something simple.
Tinted
Mar 15, 2012 02:56 PM
damageinc98
Jul 12, 2010 10:47 PM
stormshadow1
Apr 23, 2009 09:46 AM
95_Blazer
Dec 6, 2007 09:44 AM
Deezy
Oct 25, 2007 08:58 PM
