General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Acceleration drains the power
Old Jul 29, 2006 | 11:32 PM
flowmasta's Avatar
flowmasta is an unknown quantity at this point
Default Acceleration drains the power
ok so recently i put in a new alternator and flowmaster exhaust....right after i put in the exhaust my cars voltage meter gets drained with healthy acceleration....any ideas?
Old Jul 29, 2006 | 11:38 PM
Aquahallic's Avatar
Aquahallic is an unknown quantity at this point
Default RE: Acceleration drains the power
if you replaced the alternator because of the battery not charging... or sometimes the batter will get weak and pull the alternator so hard to try to keep up it'll burn up the alternator.
so check your battery.. and sometimes when they do a load test on it it'll checkout fine.... but when under a constant load for a little while it'll get weak and pull hard on the alternator so check that battery good... I just did an alternator last week and did the battery too... My alternator yacked because of the battery....
Old Jul 31, 2006 | 07:42 PM
flowmasta's Avatar
soo ur saying the battery could be causing it....any1 else got any suggestions
Old Jul 31, 2006 | 11:16 PM
Aquahallic's Avatar
well here's why I say that... it happened to me...LOL
what happens is.. the alternator sustains and charges the battery during running. If your battery is weak (might not show on a crank if your engine pops right over like mine does real easy) it might not be at FULL capacity so when you're running..... the alternator is workin' its yang off tryin' to keep the engine powered, lights, A/C, Stereo.. and so on and so on.. and now if the battery's a little weak... now THAT'S addin' a drain to it too..... it happened to me... I'm not sayin' that IS your problem.... only that it WAS mine...:P
Old Aug 1, 2006 | 01:42 AM
flowmasta's Avatar
ahh i see ight ill look into it
huehl31589
Sep 28, 2019 08:20 PM
tdbone1
Dec 20, 2012 09:40 AM
01 blazer
Nov 29, 2010 08:21 PM
ccyne
Feb 28, 2009 12:01 PM
lbauer
Feb 23, 2009 09:08 PM
