General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
a-arm bushings missing 98 blazer
Old Oct 18, 2006 | 11:33 PM
gmaltese's Avatar
gmaltese is an unknown quantity at this point
Default a-arm bushings missing 98 blazer
hello again
was greasing the front end to try to get rid of the funny noise when i looked up and saw that the pass side upper a-arm bushings have rotted away (215,000 miles) is it easy or hard to replace these bushings? any thing i need to watch out for? thanks glen
Old Oct 19, 2006 | 12:58 AM
Chevy Lover's Avatar
Default RE: a-arm bushings missing 98 blazer
Well....it's not as easy as changing your spark plugs.
You first need to remove the upper control arm. That means separating the upper ball joint, removing any clips and bracketts for the ABS wiring and brake hoses, marking and removing the alignment cams.
When you have the upper control arm off, then you can tackle the control arm bushings. By the sound of things, your bushings are going to be difficult to remove fron the shaft...Got a torch?
Once you have the bushings off, I would recommend replacing the shafts and the bushings. The bushings have to be pressed on to the shaft.
I would suggest that if you have tools and skill, remove the control arm and have a shop replace the bushings (and shafts if nessessary), then install the control arms and go get an alignment.
Hope this helps in your decision making.
Old Oct 19, 2006 | 05:48 PM
gmaltese's Avatar
thanks for your input... helpfull
Old Oct 22, 2006 | 08:58 PM
lunatic_magnet's Avatar
lunatic_magnet is an unknown quantity at this point
ORIGINAL: Chevy Lover
ive always found this the best way to do it. the professionals can do it much faster and it beats me fighting with them - especially trying to get the old bushings out.
haulincats
Oct 5, 2011 07:46 PM
cage47
Jun 11, 2010 12:17 PM
99whiteblazer
Oct 27, 2007 01:24 AM
TripleBlackBlazer
Sep 19, 2007 08:48 PM
Major Pain
Suspension Tech
Dec 17, 2005 08:37 PM
