General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
back up light
Old Nov 3, 2006 | 02:02 AM
3eyes's Avatar
3eyes is an unknown quantity at this point
Default back up light
I am looking for some help on my 97 2 dr. auto. The back up light comes on in neutral and not reverse. Can I do this? Where and what do I move? Thank You
Old Nov 3, 2006 | 03:31 AM
Chevy Lover's Avatar
Default RE: back up light
Welcome to the forum.
Apply your parking brake.
On the left side of the transmission is the neutral switch.
Loosen the bolts so that you can rotate the switch, turn the key to the "on" position, put the shifter in "R" and rotate the switch til the backup lights come on. Tighten the switch and double check.
If you have any trouble, let us know and we'll find you a picture.
Old Nov 3, 2006 | 06:02 PM
mudsliner's Avatar
mudsliner is an unknown quantity at this point
i got sort of the same problem but when i put mine into reverse (5spd) mine back up lights go on and off what would cause this?
Old Nov 3, 2006 | 09:13 PM
lastcoupe's Avatar
lastcoupe is an unknown quantity at this point
The manual trand has a switch SOLELY for the B/U lamps.....it's very common for them to stick open or burn the contacts up. It's a two-wire switch (at least one of them is green)screwed into the side (IIRC the passenger side) of the trans. Replace it and you'll be good-to-go.
hoebob69
Sep 4, 2014 08:57 PM
Kaffeene
Sep 23, 2012 12:00 AM
muskrat358
Mar 6, 2011 12:56 PM
damageinc98
Jul 12, 2010 10:47 PM
timetoblaze
Sep 12, 2004 10:23 PM
