General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Brake groan
Old Oct 8, 2006 | 12:09 AM
frankjc's Avatar
frankjc is an unknown quantity at this point
Default Brake groan
My 99 Blazer has been making a brake groan noise when I stop at a light. It makes the noise after the car stops, and "bounces". It seems to be coming only from the l/f wheel. It seems if I put more pressure on the pedal, it doesn't do it, or not as bad. If I hold the pedal with less pressure, and let the car move a bit at idle, it groans. The pads, and rotors were new in May (I think it was May anyways, but definately in the last 6 months). When I replaced them I filed the rust off the caliper cages where the pads sit, and applied anti-sieze to it. I cleaned the surface where the rotor sits on the hub. I applied black synthetic grease to the sliders.
I did take it apart a few weeks ago to replace the ball joints. I wonder if I messed something up then.
I am not sure what could be causing this. Pads? Rotor? Caliper hanging up? The car seems to stop fine.
Old Oct 8, 2006 | 12:12 AM
93s15jimmy's Avatar
93s15jimmy is an unknown quantity at this point
Default RE: Brake groan
all the vehicles i've owned and driven have done that. i think it's a normal noise...but i could be wrong on that.
Old Oct 8, 2006 | 12:16 AM
frankjc's Avatar
I hope it's normal. Like i said, it seems to brake ok. My wife drives this car more than I do, so maybe I am just not used to it.
Old Oct 8, 2006 | 03:08 AM
Chevy Lover's Avatar
If you're not sure, take it to a brake shop for a free road test and inspection. You don't have to agree to have it fixed, but you can get the opinion of a proffessional.
You don't want to be unsure of your brakes.
Old Oct 8, 2006 | 03:40 AM
20Blazer00's Avatar
Most of my cars that I have owned have done this. It might take your pads a while to wear down but they will still do this for a while. I replaced the rotors and pads on my 1999 G/A and the new rotor squeaked on the passenger side for a while... This issue may also be something that will go away over time....so unless you lose your brakes completely I would not worry to much about it...consider it a feature of new brakes...
tjmicsak
Apr 19, 2012 09:53 AM
Klturi421
Aug 13, 2011 10:35 PM
cide
Mar 23, 2009 10:57 AM
dashyman
Jan 12, 2007 11:28 AM
nwander
Jan 24, 2005 01:19 PM
