General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
bucking
Old Feb 20, 2006 | 01:10 AM
sb355's Avatar
sb355 is an unknown quantity at this point
Default bucking
let see her my problem is every once in a while, but now getting worse, my truck will start to stall even while my foot has the pedal to the floor. well more like i was cycling the key on and off. the fuel pump is good, and has a new filter on. So i would say not a feul prob. also while this happens my dash goes nuts, none of my gauges work until i shut down and restart. any help would be greatly appreciated.
Old Feb 20, 2006 | 11:11 AM
sb355's Avatar
Default RE: bucking
also this is only happening when i shift into 2nd gear no other gears. and if i push in on the clutch it will idle around 500rpm for a couple mins then go up to 2000rpms.
Old Feb 20, 2006 | 11:54 AM
Hanr3's Avatar
Default RE: bucking
This sound similar to a pcm short related to the tranny circuity, however I don't know enough about it to offer any real advice. I think there is a TSB for it. Maybe someone else can elaborate on it more.
Old Feb 20, 2006 | 12:37 PM
sb355's Avatar
Default RE: bucking
couldn't find a TSB on a manuel tranny but thanks anyway
Old Feb 20, 2006 | 02:35 PM
strongboy2005's Avatar
strongboy2005 is an unknown quantity at this point
Default RE: bucking
If your RPMs are sticking, your engine may have carbon buildup. Might need to do a seafoam treatment...
Old Feb 20, 2006 | 03:29 PM
sb355's Avatar
Default RE: bucking
got it fixed was a bad pos connection at battery and a bad ground wire. thanks for the help though
Sparky
Jul 16, 2011 10:14 PM
maxell12342003
Dec 21, 2009 04:32 PM
corvette535
Mar 10, 2009 05:46 PM
rusignuolo
Feb 19, 2009 06:49 AM
ChurchvilleMcBlazer
Jun 24, 2008 08:46 PM
