General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Clunking sound in 1995 chevy blazer
Old Feb 5, 2006 | 08:53 PM
cool2drblazer's Avatar
cool2drblazer is an unknown quantity at this point
Default Clunking sound in 1995 chevy blazer
I own a 1995 2 dr chevy blazer and when ever i make left hand turns at speeds over 30-35 mph ther is a clunking noise that comes from the back of the truck. Then when the turn is over there is no longer the clunking. Any ideas on the problem it will be helpful.
Old Feb 6, 2006 | 07:29 PM
Hanr3's Avatar
Default RE: Clunking sound in 1995 chevy blazer
Do you have a locker or limited slip in the rear axle?
Old Feb 7, 2006 | 10:01 PM
ric6312's Avatar
ric6312 is an unknown quantity at this point
limited slip,,my o5 does the same thing
Old Feb 7, 2006 | 11:54 PM
Definitely sounds like something is amiss in the rear diff. I'd pop the cover to make sure that nothing is broken. I don't think a properly working limited slip (posi) should make clunking noise while turning.
Old Feb 8, 2006 | 11:24 PM
It is a limited slip diff and i have already pop the cover off and looked at the inside and everything seemed to be ok. You guys have any more ideas becuase i can't think of anyhting other things that coudl be wrong with it. thanks
Old Feb 8, 2006 | 11:39 PM
4lowlife's Avatar
Can you "feel" the clunk while driving? Check the sway bar links, bushings, where the links mount to. Such as the frame. Look for broken bolts. Check to the leaf springs, U bolts, the entire rear suspension for any thing broken/ out of wack. Oil up the leaf spring shackles.
Jump up and down on the rear bumper, may hear something there. Check the spare, make sure its snug. Not swaying.
Old Feb 9, 2006 | 07:09 PM
I can kinda of feel the cluncking when driving. I looked at the suspension and every thing is ok. I oiled and greased the suspension parts and it helped. Could that have been the problem or could there still be something else that could be broken. Thanks for teh help.
Old Feb 9, 2006 | 09:38 PM
DaveLance's Avatar
DaveLance is an unknown quantity at this point
You may want to check the torsion bar crossmember to see if it has been hitting the frame.
Old Sep 13, 2006 | 11:11 AM
vaderblazer's Avatar
vaderblazer is an unknown quantity at this point
I had this exact same problem with my blazer and I just got it fixed yesterday. The torsion bar mount needs to be replaced, it's probably almost completely deteriorated. Take a crow bar and pry up on the mounts, if it moves you've found your problem.
BluBlazin
Jan 14, 2011 05:58 PM
musclecar70sfan
Nov 7, 2010 08:48 PM
bobbyj42
Feb 3, 2009 08:01 AM
mikeinwi
Jan 13, 2009 01:09 AM
tankie88
18
Jan 27, 2006 05:33 PM
