General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
code 43
Old Sep 12, 2006 | 09:09 PM
ron36535's Avatar
ron36535 is an unknown quantity at this point
Default code 43
I have a 1995 S10 Blazer 4X4. I have a code 43, which is the electroic spark control. I'm not sure what part I need to change, or if there is even a part to replace.....help in south alabama..
Old Sep 13, 2006 | 04:47 AM
20Blazer00's Avatar
Default RE: code 43
I hope this helps, but i think what you are looking for is the little module next to the coil, it is called the ignition coil driver module. Here is some information to check it with a Digital Volt Meter:
1. Disconnect the ignition coil driver module connector.
Turn the Ignition ON.
With a DVM, check voltage on terminals A (pink wire) and D (white/black wire) to ground. [10 Volts]
Do both terminals measure above the specified value?
2. Connect a DVM on the AC scale to the ignition coil driver module connector terminal B (white wire) and ground.
Crank the engine and observe the voltage.
Is the voltage between the specified values? [1-4 V]
Probe the ignition coil driver module connector terminal C (black wire) with test light to Battery+.
Does the test light light up?
92s10Blzr
Dec 7, 2009 03:12 PM
nitro7
Dec 1, 2009 06:27 PM
98blazr
44
Aug 21, 2009 01:17 AM
lostatsea85
Jun 30, 2008 10:06 PM
lostatsea85
Jun 23, 2008 02:44 PM
