General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Code P1810 ATF Manual Pressure Switch Malfunctio
Old Jul 2, 2006 | 09:58 AM
acarlson's Avatar
acarlson is an unknown quantity at this point
Default Code P1810 ATF Manual Pressure Switch Malfunctio
Anyone know where this switch is so I can replace it? Hope it is not inside the transmisson!
Truck still works normally, so do I really need to fix it?
Old Jul 2, 2006 | 03:14 PM
Chevy Lover's Avatar
Default RE: Code P1810 ATF Manual Pressure Switch Malfunctio
ORIGINAL: acarlson
What year/ make/ model/ etc????????
Old Jul 2, 2006 | 03:37 PM
The pressure switch is mounted on the valve body.
Check the trans fluid level, first.
is your fluid clean? It could be as simple as a sticking valve.
Old Jul 3, 2006 | 03:37 PM
acarlson's Avatar
Sorry to have forgot the obvious
1996 4X4 Rockport 103,000 km or 60,000 miles
Old Jul 3, 2006 | 03:39 PM
acarlson's Avatar
Will check and advise.
Old Jul 3, 2006 | 03:55 PM
acarlson's Avatar
Oil is clean and at the correct level. I had engine oil and filter changed 1000kms ago.
Is the valve body inside the transmission housing so the transmission oil pan has to be removed to access the switch? Stone gards will also have to be removed.
Old Jul 3, 2006 | 05:54 PM
You should check to be sure, as I don't have a manual for a 96, but the newer Blazers have the switch inside the transmission. You would have to drop the trans pan, (might as well replace the filter while you're in there). Then you should be able to see the switch on the valve body. I don't believe you have to remove the valve body.
Old Jul 3, 2006 | 11:55 PM
acarlson's Avatar
Thanks for the info
Will check with my shop tomorrow when in town.
Old Jul 4, 2006 | 03:52 AM
ORIGINAL: acarlson
Thanks for the info
Let me know when you find out. I don't want to be giving out bad information. I'm learning too.
[IMG]local://upfiles/2910/830DEAA7ACEE4C3489A733F8008F3B2B.jpg[/IMG]
Old Jul 5, 2006 | 10:00 AM
acarlson's Avatar
Transmission shop says they have to go in to the tranny and fix a valve as it controls the lock up. It will take 2 hours and parts they have in stock.
They say it is common but I could not find any posts on it. Curious!
