General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
crazy blinkerz
Old Mar 20, 2006 | 02:13 AM
powwowblazer's Avatar
powwowblazer is an unknown quantity at this point
Default crazy blinkerz
when I step on the brake it stops blinking. the lights and fuses work fine. changed the relay behind the glove and the new relay blinked even crazier. any ideas
Old Mar 20, 2006 | 08:22 AM
Default RE: crazy blinkerz
You should pull off your tail lights and check out the condition of the bulbs and sockets. Sounds like you are getting voltage leaking between the turn signal and brake light circuits. I'm betting you'll find some corrosion in the sockets out back.
Old Mar 22, 2006 | 05:21 PM
Ill check it out, thanks Ill update what I find
Old Mar 22, 2006 | 06:07 PM
Hanr3's Avatar
Buy new bulbs, and some dielectric grease first. Once you get them out, clean up the sockets, put in some dielectric grease and the new bulbs.
Bet that fixes your problem.
aris_unlimited
Street N Strip
Jul 21, 2006 02:50 PM
zero psi
Mar 21, 2006 10:50 PM
m00nwater
Aug 23, 2005 09:22 PM
BOSTONGEORGE
Jun 24, 2005 12:40 PM
