Dex Convert?????
Ok... havin' read all this stuff about Dexcool I went and looked in the Rad. of this thing (couldn't remember what was in it and it was full when I bought it and still is) and looks like someone did a green convert on this one. Still looks kinda nasty in there like they weren't real thorough... now looks like there's still a nasty *** brown film in the rad and prolly everywhere else. My question is... should I just live with it and maybe just do a FULL flush with a waterhose on EVERYTHING and change the thermostat. OR Should I get something and run it through it then flush it well with water.... I've just never been a fan of the "Rad Cleaners" from what I gather on them it's prolly somekind of solvent and I just can't see it bein' real good puttin' something like that in a system that's full of nooks and cranny's and gaskets that might decide to breakdown.....:/
Maybe it'd be ok to disconnect the hoses from the rad and cap off the bottom and fill only it with something that'd "Flush" it out????
FYI it never heats up stays around 180 190...
hmmm.... long as that mess hasn't screwed my temp sender....:/
ALL comments welcomed... "PLEASE"
My blazer has always had green antifreeze in it since I bought it. What exactly are the pros and cons of the dex-cool? what about the green kind?
Never mind about the question about the pros and cons...I found another thread about all that.
Sounds like you have either air contamination or coolant cross contamination.
In short, without going into the dexcool debate, you can switch to the "green coolant". I do not know if the standard flush kit that you can buy at the parts store will work or how many times you have to flush it. However, I use a power flush and flush it three times to make sure that there is not any dexcool hiding, for example in the heater core.
DINO55
235
Nov 25, 2011 10:22 PM
