Driver's Side Highbeam Dead!?
So im swapping my stock housing for halos, so i switched everything over and then go through the parking lights, lowbeams and highbeams. But when I go to put the highbeams on my left one is out, so i giggle it....nothing. Then I swap the left highbeam bulb (9005) for the right highbeam bulb....still it doesnt light, i keep switching the highbeam bulbs back and forth and nothing. So i look at the wires coming into the plug, ive even sprayed electrical cleaner into the plug and tried the bulb again. Still nothing, so does anyone have and idea of why my left highbeam socket wont light a bulb?
RE: Left Highbeam bulb out
Dude i'm having a similar problem. Here's the thread I started. Tell you the truth i've done nothing about it.
Here's my post: https://blazerforum.com/m_40060/tm.htm If you want try running a wire from the functioning high beam to he non-functioning highbeam (like I did.) Temp. fix. your best bet is to do what Chevy lover told me to do. If that doesn't help then follow and inspect those wires all the way to muli-function switch. If it sounds like pain in the a** to you, then you feel my pain and that's exactly why i haven't even messed with it. |
check ALL of your fuses and relays--the high beam circuits also include the daytime running lights and automatic headlights---same problem when i put my halos in--blew the DRL fuse---check that you didnt break the insulation in the high beam bulb or knock the little spring off of the back (carefully pull back the rubber cover) [8D]
Yea the bulb is ok, and i already took out the DRL fuse, maybe i should place it back in and take it out again?
Hey! I got it fixed! I put my DRL fuse back in and it works, so ive come to the conclusion that i need the fuse in there, but i dont want DRL, so what pin do i bend in order to disenguage them?
There are 5 pins with the number 1-5 beside them, this is a 98 btw. -Luke |
numbers 1-5 on a 98? weird... maybe put on your glasses? the pin is number 86..... make sure you've got the correct relay :D
edit--also you bought this used?? perhaps the reason it worked after you put the fuse back in is the relays pooched or possibly the wrong style---if you have a multimeter, check the fuse for continuity im just tossing things out there [8D] |
Its the right Fuse. Black, square and it's labeled DRL on the fuse diagram.
The pins are arranged just like the dashes below - - - - - Ok i just went out and checked, ok there are two things labeled DRL One is a big black square and the other is a accual black fuse. I looked at both and didnmt find anything labeled 86. What do i bend, a pin in the big black square or the small fuse? And if its the fuse, which pin do i bend? There are 2. O also, im guessing that the big black square = the relay and the small black fuse = DRL Fuse. Am i correct? |
I got it, my pins weren't numbered, so i had to get some pics, but im ok now.
you bend the middle pin? i think thats what would be #86.....
Personally, I would suspect the DRL relay as being bad, check it with an ohm meter.
The left lamps use the relay to get a ground connection. According to the schematics in my Chilton book, When DRL is engaged +13.8 comes down the DRL fuse, into the DRL relay and goes through both the left and the right lamps in series, so each is getting half of 13.8V in order to run the lamps in an undervolt condition. With DRL off the left side is grounded through the relay, allowing full brightness to the left lamp. If the contacts in the relay are bad this will result in the left side not functioning at all. The right side is already grounded so this allows it to function without the DRL relay. TheDesertFox: I believe you are having trouble distiguishing fuses, relays and diodes. Removing DRL fuse 15 which is 10 amp and should be blue should disable DRL, but the DRL relay, which is the square thing I believe you are refuring to must be left in place. Reportedly some models had a diode in the fuse block that you remove and it disables the DRL but I do not have one of these for some reason. Diodes are usually round cylanders, black in color and will always have a stripe on one end or the other denoteing polarity. |
isnt that what i said to do? [sm=bustedsign.gif]
[sm=funnypostabove.gif] |
i had the same exact prob this helps alot
YEa but my pins werent number :D
