-   General Tech Help (https://blazerforum.com/forum/general-tech-help-7/)
-   -   EGR Valve (https://blazerforum.com/forum/general-tech-help-7/egr-valve-5367/)
Dan Sep 8, 2006 12:32 PM
EGR Valve
I need a little help here. I was going from Middle GA to the top of TN last night and about 440 miles into the trip (20mi from my exit) my Service engine light came on. The truck was running fine at about 85mph but once I hit a red light off the highway it stalled and took a few cranks to get it to start back up. It runs very rough at idle but if I give it a little gas it seems to do fine. It is saying Code 32 which basically says "Vacuum switch shortened to ground on start-up or switch not closed after ECM has commanded the EGR for a period of time. Replace valve. * If you disconnect the EGR and run the Ultimate on T1-15 it may set this code." can anyone translate that to "Hit It With A Big Hammer" lol. If not can you give me some How To's without spending any money. I am on a VERY VERY tight budget. Thanks in advance.
swartlkk Sep 8, 2006 01:02 PM
RE: EGR Valve
Based on the code, I'm assuming this is on your '93.
I'm not sure of the design of the EGR valve on the TBI or early CPI motors. I also have not heard of them clogging like the SCFI EGR valves do. But you could try to clean the valve itself, removing any carbon buildup that may be present and holding the valve open or restricting the motion of the valve pintle.
At most, you're looking at a new gasket for the EGR valve and some carbon cleaner.
Dan Sep 8, 2006 02:14 PM
RE: EGR Valve
Alright. Well is there any way that you could scan me a picture of it and tell me where it is. I would greatly appreciate it since I left my manual at home. Thanks
Dan Sep 8, 2006 02:19 PM
RE: EGR Valve
Another thing will it hurt it to continue to drive it because the only thing effected is the idle?
swartlkk Sep 8, 2006 02:30 PM
RE: EGR Valve
All of my references are at home right now so I can not access them. Lets see if someone else can get you a picture.
About driving it... Well, it won't be as efficient, but the pcm should compensate for it and keep the motor from running lean. Shouldn't be too bad to drive it. You may end up with carbon fouling of the plugs, but plugs are cheap.
