-   General Tech Help (https://blazerforum.com/forum/general-tech-help-7/)
-   -   findin' the kickdown cable (https://blazerforum.com/forum/general-tech-help-7/findin-kickdown-cable-3103/)
chevy8jr Apr 5, 2006 08:59 PM
My tranny seems to shift wrong. It seems the rpm's go up too high when goin' out of first gear. It is a A/T. But i was told to check the kickdown cable to see if it needs to be adjusted. My dad could'nt remember were it is. He thinks some people call it something else. Can someone help me find this cable. Thanks
Hanr3 Apr 6, 2006 12:17 PM
RE: findin' the kickdown cable
It is called something else. It is called a TV cable, as in trottle valve cable. It does more then just downshift the tranny like the old kickdown cable did in the earlier TH350 trannies the 700R4/4L60 tranny replaced.
The cable is located on teh passengers side of the engine, it is connected to the trottle linkage and runs down to the passengers side of the tranny. Now if your truck is '93 and newer, you wont have a TV cable, your tranny is electronically controlled.
I would make sure your tranny has the proper amount of tranny fluid in it. Drive it for 20 minutes, stop on a level surface, leave the engine running and check the fluid. Add as needed.
magtec Apr 6, 2006 06:20 PM
while you're checking the transmission fluid level, make sure the fluid is the right color and doesn't smell bad.
chevy8jr Apr 6, 2006 07:30 PM
The tranny fluid at level, dark in color, it smells the same as the new stuff i got.
I have like almost no accelertion when i go from a dead stop. Can the tv cable
be adjusted at all?
magtec Apr 6, 2006 07:39 PM
dark as in red, or dark as in brownish?
chevy8jr Apr 6, 2006 07:53 PM
dark in brown. I just take it for a ride & i can push the gas pedal to the floor
& no more power to go faster. Im will take it in tomorrow & see what they say.
thanks guys.
magtec Apr 6, 2006 10:05 PM
if the fluid is brown it needs to be changed.
when it seems like there's no power, does the engine rev very high or does it just kind of bog?
chevy8jr Apr 6, 2006 11:15 PM
The rpm's don't rev that high around 2500 rpm's with the pedal to the floor.
It speeds up slowly. I think it maybe the fuel filter, theres no boggin' or stalling at all.
So i know it's getting fuel. my coil could be bad too. There so much things that it could be wrong with it.
magtec Apr 6, 2006 11:18 PM
the catalytic converter might be clogged. does it rattle if you bang on it? if you partially plug the tailpipe does the engine operation change drastically?
chevy8jr Apr 6, 2006 11:48 PM
I just got back from doing what you ask me. The cataltic converter is solid, no rattles. I even bang on the muffler too, its solid too. There was no change in the engine when partialy plugged, i held it they for 30 seconds.
