General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Fuel Lines on a 91 4.3L
Old Aug 17, 2006 | 03:36 PM
primodtr's Avatar
primodtr is an unknown quantity at this point
Default Fuel Lines on a 91 4.3L
Hey guys,
windering is anyone has replace the hard lines that run along the frams back to the tank, I just repalce the fuel pump, and the lines look pretty bad, and one leaks so I'm going to rpalce them. just wondering if anyone has replace the 3 hard lines, and if chevy or someone sells the lines or if I'f have to get some fuel line and a bending tool.
thank a ton
-Ben
Old Aug 17, 2006 | 09:40 PM
Default RE: Fuel Lines on a 91 4.3L
I'm not sure if GM still supplies these parts for your year. If you can get the proper connections, I would replace it by bending your own lines. Carefully remove the original lines and then copy them.
Are you sure you need to replace all 3 of them? The two smaller lines are a vent line and a return line. Both of which shouldn't have hardly any pressure in them. The large line is the main fuel supply line. You may be able to get away with just replacing the main line from the filter back to the tank...
Good luck!
Big Eazy
Apr 27, 2013 12:48 PM
skid9832004
Jun 5, 2011 01:38 PM
dj00140
Apr 13, 2011 10:48 PM
rcollins
Engine & Internal
Jun 21, 2006 11:28 PM
