97 s10 major fuel leak where fuel lines go into spider
Old Apr 26, 2013 | 07:05 PM
Big Eazy's Avatar
Big Eazy is on a distinguished road
Default 97 s10 major fuel leak where fuel lines go into spider
How can I get the 2 plastic tubes out to change the Orings?
Old Apr 26, 2013 | 07:21 PM
bear159's Avatar
bear159 is on a distinguished road
On mine there was a small clip you had to pull out where the lines meet the injector, then you could just pull the lines off.
Old Apr 26, 2013 | 07:58 PM
Big Eazy's Avatar
This one just has the retainer clip that holds the fuel lines down but nothing appears to be holding the plastic tubes in place maybe they just pop out?
Old Apr 27, 2013 | 12:48 PM
okiedoak20's Avatar
if you can remove the retainer clip, check for a small bolt if not the tubes chould wiggle and pop out, but the lines do need to be unbolted from the back of the motor to have enough room to move
hunter05
35
May 16, 2024 09:01 PM
hunter05
Mar 29, 2014 11:32 AM
ark steve
Dec 12, 2013 07:50 AM
kerander
Sep 29, 2011 05:24 PM
