fuel pump
hey all, my truck was at circuit city getting a stereo installed and when i went to start it up, the battery was dead and the fuel pump had failed...does anyone have any idea how these could be related?!? could the installer have messed up somthing or pulled a wire somewhere?!? any and all comments would be appreciated!!
RE: fuel pump
i just got a call from the mechanic and he said that the pump, strainer, filter, and level sensor all need to be replaced at a total cost of $966 and some change. i asked for the labor cost and he said $360...that works out to $600 for parts. LMC truck offers the same parts for $170 total. a little help please?!?
RE: fuel pump
You can do the repari yourself and save a ton of money.
I paid $280 for a new fuel pump/sending unit for my '00 S10-Blazer. Took about 2-3 hours in my driveway to swap in the new unit. $600 for parts is outragious. Event eh dealer pump is only $350. If your going to do it yourself, post up and we can walk you through it. Its not hard, but you do have to ge the right part (tag on old unit with correct version of part on it), and you won't know which part (based on tag) to get until the gas tank is out. |
RE: fuel pump
and go back and slap that mo fo at CC
RE: fuel pump
short circuit city
RE: fuel pump
Speaking of fuel pumps, I just noticed yesterday that the fuel pump is making a sound like a cellphone on vibrate mode for about 5 seconds after I turn the key off (I assume it's the fuel pump, the noise is coming from the passenger side rear below the floor area). Is this something it was doing all along and I just noticed it now, or is this a problem ? |
RE: fuel pump
mine makes about the same noise. that's just the relay and the motor kicking off.
RE: fuel pump
That's a relief. |
RE: fuel pump
yea, fuel issues are scary. damn costly pieces of crap they are
RE: fuel pump
ive put 2 fuels pumps in my blazer in 3 years 450 each time it is done....both of them before they went out they started to make alot of noise.. :)...
