General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Headlights not working
Old Nov 13, 2006 | 01:29 PM
virgs91s10's Avatar
virgs91s10 is an unknown quantity at this point
Default Headlights not working
I have a 91 s10, and I cant get the headlights to turn on. If I hit the switch, the parking, tail and dash lights come on, but no headlights. Any ideas or troubleshooting tips would be appreciated.
one more question, this may or may not be related. If I clamp on an ammeter on the neg cable of the battery, it reads 25 amps DC with the truck running, and about 600mA with it off, is this normal, or am I doing something wrong.
Thanks
Old Nov 13, 2006 | 03:54 PM
Chevy Lover's Avatar
Default RE: Headlights not working
I don't suppose it's possible that you have 2 burned out headlights? Have you tested the connectors for power and ground?
Old Nov 13, 2006 | 04:26 PM
I can't overlook the obvious "Did you check your fuses" response...
Old Nov 13, 2006 | 05:32 PM
20Blazer00's Avatar
If hitting the switch causes your other lights to come on then I would say get a bigger hammer and push those electrons farther down the line....(LMAO).
Seriously it sounds like your headlight switch might be the answer but check your fuses also. I would check the back of the switch to make sure that the connectors are fully seated and making good contact.
Old Nov 13, 2006 | 10:19 PM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
Seriously... check the drivers side headlight assembly fuse under the hood..... if it is blown then parking lights and everything will work, but neither set of headlights will work... sounds crazy but its true... your passenger headlight is controlled by your drivers side headlight.. I just had some headlight troubles and it was the fuse in the box under the hood... check the ones for the driver and passenger sides... thats probably what it is.... if not, troubleshoot your drivers side headlight first...... it could be causing the problems because it also controls your passenger headlight...
big_charms@hotmail.com
Mar 20, 2014 10:26 PM
mjw1991
Feb 24, 2013 10:18 PM
sonic2552
Sep 11, 2010 11:54 PM
my96willkillu
Feb 12, 2009 07:31 AM
DevizesChris
Oct 15, 2007 02:54 PM
