General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Help won't run
Old Oct 4, 2006 | 09:16 PM
Corvettemick's Avatar
Corvettemick is an unknown quantity at this point
Default Help won't run
I have a 96 Blazer with the 4.3L V6. It ran one day and next it won't start. I have poured gas down the throttle body to determine if it fuel or electrical. It will run as long as I pour gas into it. However I could hear the fuel pump cycling, so I disconnected the fuel line at the top of the intake manifold, when the key is turned to the on position gas is pumped out of the line. Ive checked the ECM fuses and niether are blown. Help what do I do next?
I'm considering parting it out, any idea what the aggragate total of the parts would be worth on ebay?
TIA,
Mick
Old Oct 4, 2006 | 09:22 PM
rabbit0102030's Avatar
rabbit0102030 is an unknown quantity at this point
Default RE: Help won't run
I wouldn't just part it out that quick. What exactly have you tried to fix it? What other symptoms does it have? Give us some more info!
Old Oct 4, 2006 | 09:43 PM
lastcoupe's Avatar
lastcoupe is an unknown quantity at this point
It's got to be fuel related if you can get it to run by spraying it. Check the fuel pressure and make sure it's adequate. What engine code is it X or W? (the 8th digit of the VIN).
Old Oct 7, 2006 | 12:31 PM
It's a "W" code. Do I measure the pressure off the schrader valve? What pressure should it be?
TIA,
Mick
Old Oct 7, 2006 | 03:49 PM
Chevy Lover's Avatar
Yes, you measure the fuel pressure at the shreader valve, fuel pressure should be 415-455 kPa (60-66 psi).
m3dragon
Feb 24, 2015 10:04 AM
finity
Mar 20, 2012 08:57 PM
Mr M
May 17, 2011 02:34 PM
Marshall1979
Mar 25, 2011 03:48 PM
Bybsurfr32
Sep 1, 2009 09:17 PM
