General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
hot air from vent
Old Dec 21, 2004 | 05:03 PM
Swblazer's Avatar
Swblazer is an unknown quantity at this point
Default hot air from vent
I have a blazer -99 with climate control air condition.
The problem is that it doese't matter where I have the temp ****. It will always come hot air from the vents.
Can someone tell me if the heat blending/mixing door is controlled by a electrical motor or vacuum cotrolled?
And where is it located in the truck?
And if someone have some wiring diagrams or vacuum diagrams to my truck.
Best Regards, need to cool down [:@]
/Sverker
Old Dec 24, 2004 | 08:56 PM
jimmy91444's Avatar
jimmy91444 is an unknown quantity at this point
Default RE: hot air from vent
i would check for a vacuum line under the hood going trough the firewall for break or crack .
Old Dec 26, 2004 | 09:52 AM
Swblazer's Avatar
Hi,
After 4 hours of work I have found out all kind of things aout the heating system in a Blazer -99 with Computer climate control.
All the dampers for air on floor, window, etc are controlled by vacuuum.
But the damper that controlles the heat is a servo motor.
Now I have a electrical diagram for a Blazer -99, someone that know where to find one?
/Sverker
Old May 24, 2006 | 01:19 AM
jlm33069's Avatar
jlm33069 is an unknown quantity at this point
I know that this is an old post but I have the same problem. Did you get the issue resolved? What did you do to fix it?
Old May 24, 2006 | 10:36 AM
Please start a new topic with your specific problem and any trouble shooting steps you have attempted.
Old May 25, 2006 | 01:18 AM
jlm33069's Avatar
I have opened a new post, it's title is "Only blows hot air ".
Mandrwj
Apr 10, 2011 07:32 PM
nuwave
Feb 10, 2011 01:28 PM
88_s10
Jan 15, 2011 05:04 PM
ScottECU
Apr 7, 2010 11:37 AM
ravenhurst
15
Apr 26, 2009 07:53 AM
