I'm out of blinker fluid...lol
hmm...i find sometimes if you're isotropically linked endothermic-isolated thixotropic equalizer isn't spinning on a perfect dihedral angle of 47.663 degrees at roughly 1902.7 RPM then your signals may not flash...........
that or the flasher unit is buggered
Turn on the ignition, turn on the left turnsignal, lie down on the floor and listen for a "click, click, click" and there it is.
Couldn't resist, must be the weather.
It is under the dash, passenger side on the '99 Blazer, probably the same on the '96.
