internal coolant leak
I rented a coolant pressure test today and observed the gauge needle drop slowly within 30 seconds. Makes me wonder if I have a leak too. I'm going to keep an eye on the catch can.
Straight from AllDataDIY.com:
Apply normal system operating pressure.
Never exceed 138 kPa (20 psi).
The needle on the tester gauge should remain steady for several minutes, otherwise there is a leak.
I forgot to mention it was tested on my Impala. It was driven about 10 min before I tested it. I couldn't pump the bastard past 16 psi. I wonder if it has to do with the fact I did not lube up the O ring on the gauge.
I'm going to run the engine tomorrow with the gauge on and wait until it warms up.
OK it's saturday the 11th and i checked the coolant this after noon weird the coolant is up there is no signs of moister on the oil fill cap and the overflo resavior is ok at a loss of knowing what to do next as soon as it warms up here in NY i plan on taking the plentum off and retorqu the intake and see if that works what do you think.oh there is a smell of antifreeeze after you shut it off can't find a leak..any ideas of what to do next?????[&o][:@]
Water pump weep hole. Check the top of the water pump for anti-freeze.
and no, coolant leaking is not common for these engines. They are extremely strong and durable engines. It is the same as a 350 with 2 pistons removed. Even utilize the same parts, internally and externally.
weep holes are fine no signs of leak around them ..I must have a dud engine i have had nothing but problems with it since i have had it .must say for the miles i have on it it still runs strong.I'm waiting right now for the rain and cold fronts to move threw so i can retorque the intake to see if this will help..will let you know if it does..[&o]
OK It's saturday 4/1/06 I had my blazer over to my buddys house and he has looked it over the moister I see on the oil fill is OK is normal good thing i don't own a new dodge hemi ..the hoses are calapsing do to a bad radiator cap so i replaced.I just replaced the upper and lower ball joints what a pain why is it they go bad every 12000-14000 miles I'm not rouph on it becouse it's my only source of transportation..![Big Grin](https://blazerforum.com/forum/images/smilies/biggrin.gif)
thank you for all your help and support with this problem now i can move on to replacing the rear pinion bearings and fix the a/c problem....john...
![Wink](https://blazerforum.com/forum/images/smilies/wink.gif)
ORIGINAL: john
As for the slight coolant leak, the 95 and older vortecs are not common for intake manifold leakage, they had a good intake manifold on them. Most likely it is a small seep in a head gasket when it is totally warmed up and running down the highway. You could pull the spark plugs and look at them, if any show a pretty birght white burn pattern, that is the cylinder that is burning the water.
As for using a pressure tester. DO NOT USE one on a hot or even a warm engine. Pressure decreases as the engine cools. A true pressure test is done to a cold engine, and left on over night. The above mentioned slight head gasket leak is nearly undetectable through a pressure test, I know, I had one.
My coolant leak was on the right side between cylinders 2 and 4, 4 being the culprit.
BEAT MY JIMMY
07-21-2010 01:13 PM
