General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Lean
Old Jun 18, 2006 | 12:18 AM
97blazer44's Avatar
97blazer44 is an unknown quantity at this point
Default Lean
I have noticed that my truck has a lean, driver side is lower then passanger side. I was told that it could be a leaf spring, but I was wondering if anyone else had thier truck lean more on one side then the other, any feedback would be very helpfull!
Old Jun 18, 2006 | 12:32 AM
Default RE: Lean
The torsion bars can be adjusted to correct for this, but you have to determine if it is a front corner causing the lean or a back corner. Measure the wheelwells side to side on the front and back. I'll see if I can't dig up some info on the proper ride height for you to compare to.
I'm betting that a simple torsion bar adjustment is necessary. Only problem you may run into is that the adjustment bolt/nut on the cam will be froze up, but a few days of lubrication with penetrating oil before the adjustment is attempted should help greatly.
portcqb
Sep 2, 2008 05:06 PM
4lowlife
Engine & Internal
Feb 18, 2007 12:40 AM
HCCAFan
Feb 5, 2007 10:35 PM
BlazerDaughter
Jan 22, 2007 08:17 PM
WarriorBlaze
Suspension Tech
Sep 30, 2006 12:55 PM
