General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Misfire/keystuck
Old Oct 11, 2006 | 05:22 PM
chucknienhuis's Avatar
chucknienhuis is an unknown quantity at this point
Default Misfire/keystuck
hey. my 00 blazer is driving me nuts, I recently had the service engine light come on for a random cylinder misfire, although there where no symptoms I did a tune up, plugs, wire, cap, rotar. The light stayed off and it ran fine for a week, now theres a misfire when I accelerate at 10 an 30 mph, and I can here an explosion in the exhast while it idles. With in a week my power seats stopped working, it won't shift to 4x4, and now my key is stuck in the ignition. The key will start and shut off the engine, but it wont return to the lock position. My question is, is their an common factor in all these problems, and what could it be?
Old Oct 11, 2006 | 06:13 PM
2dr5spdblazer's Avatar
2dr5spdblazer is an unknown quantity at this point
Default RE: Misfire/keystuck
i guess you just got a bad round of blazer my friend. time for an LS1 Swap.
Old Oct 11, 2006 | 11:20 PM
DetroitMuscle's Avatar
DetroitMuscle is an unknown quantity at this point
ORIGINAL: chucknienhuis
you need to take it in to a pro, seems you got a bug, happen to have an aftermarket alarm and/or remote start on it?
Old Oct 12, 2006 | 04:03 PM
Hanr3's Avatar
Battery!!!!!!!!
Do you still have the AC Delco battery, if so check the positive battery cable. Remove it from the battery and look for corosion.
A bad ground will do the same thing. Check the battery, both cables before oyu move to anything else.
Old Oct 13, 2006 | 01:54 AM
battery terminals are clean
Old Oct 13, 2006 | 03:26 AM
Hanr3's Avatar
I gather then that you actually removed them to verify that. I am not trying to sound condensending, its just that with the AC Delcos, it may lok clean from the outside, but the damage is on the insdie or hte battery. I have unbolted the cable and seen the terminal literally fall out and then the battery leaks acid.
If its not the battery, try replacing the ignition key, or check the ground to the ECM.
All GM vehicles have power going to the sensors, and the sensor is grounded throught eh ECM. The ECM reads the voltage and makes adjustements. The ECM is reading hte ground voltage and comparing it to what the sensor should be sending it. The ECM knows the voltage a normally functioning sensor should be sending, and it knows what it means when the voltage is different. It will compensate to get the voltage readings back to normal.
One other thing to check is the cables at teh starter. All power goes throught there, if you have a bad connection, or corrosion....
Old Oct 16, 2006 | 12:59 AM
mrspeedy69's Avatar
mrspeedy69 is an unknown quantity at this point
You may have a bad ignition. Seems like if the ignition has a bad ground or current through it, it can mess other things up as well.
rrk03300
Nov 15, 2012 10:29 PM
01extreme
Jun 7, 2006 01:48 PM
PhatKat
Mar 30, 2006 07:13 PM
wythel
27
Jan 30, 2006 02:04 AM
wolfe1967
Aug 29, 2005 12:27 AM
