need help please
i just had the head gasket and intake maifold gasket replaced on my 1998 gmc jimmy and got the truck back from my mechanic and know every so often ill be driving and all my gauges will stop working speedo will go down to 0 and rpm to 0 odometer will go blank and all warning lights will come on then they it will go back to normal what should i do
RE: need help please
I would first try removing your gauge cluster and checking the connection at the back.
However, more often than not, this is a predecessor to the ignition module failing. |
now today i started it and it wont move at all it acts like the brakes are locked up and i get a loud screeching noise and it wont move when i shut it off i cant get my key out of tyhe ignition man this thing is screwed up do you think its still the ign module
Check all wiring connections. Actually take it back to the shop that did the work and tell them the problem. No doubt he left you with a loose wiring connector, or pinched some wires.
In order to pull hte heads, and intake manifold of you have to disconnect just about every sensor wire, spark plugs, cap/rotor. |
ORIGINAL: Hanr3 Check all wiring connections. Actually take it back to the shop that did the work and tell them the problem. No doubt he left you with a loose wiring connector, or pinched some wires. In order to pull hte heads, and intake manifold of you have to disconnect just about every sensor wire, spark plugs, cap/rotor. |
