General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
No oil pressure on a 2.8L what wrong?
Old Mar 29, 2006 | 11:15 PM
toofast2ride's Avatar
toofast2ride is an unknown quantity at this point
Default No oil pressure on a 2.8L what wrong?
My dad has a 1985 Chevy Blazer S10 four wheel drive with a 2.8 liter rebuilt engine. It has new rod and main bearings, and new crank shaft with a second new oil pump in it. When it starts the oil pressure is fine, but when it warms up the oil pressure drops to nothing. He has pulled this engine twice with the problem still remaining. Some help would surely be appreciated. Tad
Old Mar 30, 2006 | 12:02 AM
magtec's Avatar
magtec is an unknown quantity at this point
Default RE: No oil pressure on a 2.8L what wrong?
has the oil pressure been tested with a real oil pressure gauge? the factory gauges are not very accurate, and it's possible that the problem is a bad oil pressure sending unit.
Old Mar 30, 2006 | 12:29 PM
Default RE: No oil pressure on a 2.8L whats wrong?
The engine show 55 psi when started, thats using a hand held gauge, but after it warms up it drops to 15 psi, and it keeps dropping. The bearings was mic. and all seems to spec. out to manufacturers recommendations. Should Dad put a high performance oil pump in this engine? He has replaced the oil sending unit also. The heads and valves have been gone through too. I'm not for sure whats left to do ????
kennycraze
Apr 19, 2011 06:25 AM
BIGGER_HAMMER
Apr 12, 2010 09:50 PM
zippy199
Oct 22, 2009 06:36 PM
Ak95Blazer
Jan 7, 2009 06:56 AM
somedudeintn
Sep 20, 2008 09:12 AM
