No Power whatsoever
I believe I hooked up a wire I shouldn't have and blew a fuse or a relay. The battery is fine, but I'm not getting a single light or any signs of life. Any suggestions as to which fuse?
RE: No Power whatsoever
first i would check to make sure the battery has a good connection
Put in as many details as you can, so someone can identify the wire and help you
If you are SURE the battery is good and you're not getting ANY power at all, then you have to have a bad connection at on end of one of the battery cables. That's the only thing that can cause a TOTAL loss of power with the exception of a bad battery of course.
Problem solved. Whoever had worked on it in the past had some wires out of place and jumpered making it difficult to see where the problem was.
