General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
No Power whatsoever
Old Oct 20, 2006 | 10:58 AM
wostibot's Avatar
wostibot is an unknown quantity at this point
Default No Power whatsoever
I believe I hooked up a wire I shouldn't have and blew a fuse or a relay. The battery is fine, but I'm not getting a single light or any signs of life. Any suggestions as to which fuse?
Old Oct 20, 2006 | 11:47 AM
hillbillyinOhio's Avatar
Default RE: No Power whatsoever
first i would check to make sure the battery has a good connection
Old Oct 20, 2006 | 12:27 PM
Chevy Lover's Avatar
Put in as many details as you can, so someone can identify the wire and help you
Old Oct 20, 2006 | 11:18 PM
lastcoupe's Avatar
lastcoupe is an unknown quantity at this point
If you are SURE the battery is good and you're not getting ANY power at all, then you have to have a bad connection at on end of one of the battery cables. That's the only thing that can cause a TOTAL loss of power with the exception of a bad battery of course.
Old Oct 21, 2006 | 07:39 PM
wostibot's Avatar
Problem solved. Whoever had worked on it in the past had some wires out of place and jumpered making it difficult to see where the problem was.
flipzat
Dec 2, 2009 04:05 PM
fresno99
Jul 31, 2009 08:12 PM
1991whiteoutblazer
Jan 8, 2009 08:17 PM
nate2003456
Jan 18, 2007 01:10 AM
freeman
Aug 23, 2005 10:55 PM
