General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Overheats one time a day?
Old Nov 20, 2006 | 01:21 AM
96Ls4Dr's Avatar
96Ls4Dr is an unknown quantity at this point
Default Overheats one time a day?
Ok wierd but....
When it's first started up in morning it overheats within 3-4 miles but if we catch it in time(before it gets to the redline and CEL comes on) we could floor it and it goes back down in like 2 seconds. WHAT COULD IT BE???
Old Nov 20, 2006 | 01:47 AM
Chevy Lover's Avatar
Default RE: Overheats one time a day?
Check the coolant level in the rad when it's cold and make sure it's full.
It's also possible that your thermostat is sticking closed.
Old Nov 20, 2006 | 10:10 AM
rooster's Avatar
rooster is an unknown quantity at this point
usually when u overheat, u can blame the thermostat. heres a quick check: next time it overheats stop the truck, open the hood and check two things. first if u got coolant coming out of the overflow res, then ur thermo is stuck closed. another common spot would be the water pump. the pump has a weep hole to allow the coolant to drain when the pumps bearings are worn. you will know its the pump when u see coolant flowing out like a stream from the pump. wait just got more ideas. if there is a white crusty corrosion around the pulleys and block then there is a hole in the rad and the fan is spreading the coolant around. also make sure the peacock is tight
Yeah, I'd vote for a sticking thermostat.
Old Nov 27, 2006 | 11:21 PM
dcup734's Avatar
dcup734 is an unknown quantity at this point
My 98" S10 Blazer had rising temperatures since I had it passed 36K miles. Don't mess around here. Avoid an OEM replacement. I bought a replacement from Summit Racing, changed the water pump too, and haven't had any problems since. These are low budget items that can save your engine.
Old Nov 28, 2006 | 12:18 AM
DetroitMuscle's Avatar
DetroitMuscle is an unknown quantity at this point
might have air in the cooling system.
Old Nov 28, 2006 | 12:52 AM
96Ls4Dr's Avatar
I know we have air in the cooling system cause it sounds like water bubbling when you step on the gas. How do you get the air out though?
Old Nov 28, 2006 | 01:15 AM
rooster's Avatar
try flushing the system, and try and flush the core as well.
Old Nov 28, 2006 | 02:27 AM
cherryred4x4's Avatar
cherryred4x4 is an unknown quantity at this point
you could also have a clog in the heater core causing the bubbling, but try everything else first for the bubbling, changing the heater core isn't fun
Old Nov 28, 2006 | 11:02 AM
To get the air out, you first have to determine where the air is coming from. I would do a complete flush as suggested above. With the flush, replace the radiator cap AND the thermostat. Both are cheap items to CYA.
Look for any signs of leakage anywhere in the system. A faulty radiator cap can allow air into the system, but just to be safe, you need to check all other possibilities. Also, if you do not have the proper coolant level in the overflow tank, you could have air ingestion problems.
Mikeman84
Feb 26, 2018 09:53 AM
Floridagirl_1021
Nov 12, 2015 12:30 PM
pbfrk4life
Oct 26, 2010 06:37 AM
Blazerdazed
Oct 18, 2010 07:58 PM
topgunfan
Jun 8, 2009 10:14 AM
