General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Oxygen Sensor 2003 Trailblazer ext v8
Old Oct 21, 2006 | 04:01 PM
jmd57win's Avatar
jmd57win is an unknown quantity at this point
Default Oxygen Sensor 2003 Trailblazer ext v8
Can you tell me exactly where the front 2 Oxygen sensors are located on a 2003 Trailblazer EXT V8? How hard are they to get to?
Thanks.
Old Oct 21, 2006 | 10:37 PM
Chevy Lover's Avatar
Default RE: Oxygen Sensor 2003 Trailblazer ext v8
Welcome to the forum.
The front O2 sensors are just ahead of the cats, and rear O2 sensors are just behind the cats.
[IMG]local://upfiles/2910/6941D158775B4332B8FC2829E73A7279.gif[/IMG]
Old Oct 27, 2006 | 05:36 PM
jmd57win's Avatar
I have located the front 02 sensors but I am having trouble getting to the connections. Does anyone have any ideas on an easy way to get to the connectors? Thank you.
Old Oct 27, 2006 | 06:22 PM
20Blazer00's Avatar
Get the correct size wrench and unscrew them from the exhaust pipe. According to the service manual it is easier if the pipes are at 120*F, anything cooler might result in thread damage etc., etc., etc., yada yada yada....
I do believe that the warmer the parts are the easier they will be to remove so get as close to that temp and wear protective gloves so not to burn yourself from the heat...
Old Oct 27, 2006 | 10:24 PM
I don't know if this is the case with your connectors, but with some I have had to unclip the the harness to lower it enough to access the connectors.
zigzag
Dec 1, 2013 08:06 PM
icry4uolord
TrailBlazer GMT360/GMT370 (2002-2009) Tech
Jul 8, 2011 07:16 AM
mearltobias
Sep 19, 2010 04:06 PM
steelcityneal
Jan 10, 2010 09:23 PM
jmd57win
Oct 27, 2006 05:59 PM
