rear hatch
I have a 95 Chevy Blazer which the rear hatch doesn't open. I can hear a noise when I press the button, but it doesn't open.
Does any one have a solution. |
RE: rear hatch
So I take this to mean that your rear hatch is not unlocking, so you cannot open it. Is that correct? Or are you having problems with the glass section?
RE: rear hatch
It is not unlocking.
RE: rear hatch
pull the inside panel carefully as not to crack it then open it manually and make the necessary repairs
RE: rear hatch
what side do you stick the screwdriver down to pop it open? How far down do you go?
I really need some one to help me. it has been almost a year since it quit working and I don't have the money to have a dealer fix it. |
RE: rear hatch
what area r u in i'm in memphis, MO. or call 1-660-465-7118
RE: rear hatch
I'll see if I can't snap some pictures of the inside of my rear liftgate for you when I get home. I will also see if it is possible to get the trim panel off without the gate open (kinda doubt it).
Can you open the glass? |
RE: rear hatch
I am in the back of the blazer trying to get the hatch to pop open.
How do I do it with a screwdriver. I don't want to tear up the carpet trying to get it opened. |
RE: rear hatch
ok i was mistaken on opening back end. does your back panel wrap around the hatch? i have a 2000 and it does so popping the panel off is out. can you send me a pic of your whole panel and a close up of the latch area?
mtncrsr@yahoo.com scotty PS: to do mine i would drill a hole near lthe latch and then use a crome plug (from the hardware store ao auto parts store) to fill it. also ineed to know if you open the glass is there a small gap at the top of the bottom tailgate there is in mine. i will dig out my safe light and see if there is a easer way. i will get back to you later day. |
RE: rear hatch
do not drill a hole untill i investigate further and get back 2 u!!!!!!!!!!!!!!!!!!!!!!!!!
